Two clicks to change name
orbspider
Post by orbspider »
If a file is clicked on twice the name can be changed -which is great for changing the name!
But what happens if a file is clicked twice by mistake, meaning to select it and tag it......
  • The name highlights for name-change but I hit Space to tag the file!
    The file name is reduced to a single space!
    If I don't realise what I've done it will be hard (especially if it is in a DB filter and all mixed up folders) to restore the right file name
May I suggest two clicks on the file name allows name change. Not two clicks on the thumbnail. thanks
Re: Two clicks to change name
yes already asked
budz45
Post by budz45 »
orbspider wrote:May I suggest two clicks on the file name allows name change. Not two clicks on the thumbnail. thanks
Yes it should be on filename only and not on thumbnail
