Hello. I apologize if this has been asked before, but I have searched and didn't find an answer.
I have a few pictures with numbers at the beginning, for example:
and so on.
I wish to remove the numbers and the underscore but leave the 'Tree' part. The files are a series, but I do not have all of the pictures in the series, I am missing a few. Therefore, I cannot just rename to "Tree##" and keep the same numbers the images currently have.
I have tried doing a replace using *_ but it doesn't recognize that. Is there a way to remove the numbers and underscore without having to rename each image individually?
Thanks for the help!
Drew
Batch Rename of files to remove numbers.
Re: Batch Rename of files to remove numbers.
Sorry but not possible
Ant Renamer can do that: http://www.antp.be/software/renamer.
No doubt some of the many other freeware renaming utilities can also do it.
DrewLow
cday wrote:Ant Renamer can do that: http://www.antp.be/software/renamer.
Thank you, I will try that.
