Hello there,
I like and use XnView a lot.
But I cannot find a complete list of command line options.
Unfortunately a xnview.exe -? (or -help or /? or /help) is not implemented.
One thing I want to achieve is building a shortcut that starts XnView in capture mode.
Yes, I know there is this nice post http://newsgroup.xnview.com/viewtopic.p ... 895#p51895 that handles command line capture parameters.
But I need my particular options (hotkey, target dir, file format, multiple captures), that are not mentioned there.
Hence my question...
Best regards, Farbauti.
Complete List of Command Line Options?
Farbauti
oops66
Re: Complete List of Command Line Options?
+1 I support to support a complete list of command line options and parameters for XnView & XnViewMP.
For Windows:
xnview.exe -?[/b] (or -help or /? or /help) is not implemented.
or for Linux, mac os...
xnview --help (or man xnview)
For Windows:
Is "Command line help" dialog in XnView what you are looking for? You open it using menu "Info > Command line help".
In XnView MP the command line options are planned to be listed in the "About" dialog, which you can open using "Help > About...", tab "Command line". Until now this tab is empty (not intentionally).
+1 | Even though the info might be there, I support your request of having something like a --help option for outputting command line options.
Farbauti
Not quite. It does show the options (e.g. "-capture") but not the available parameters (e.g. "=desktop,d:\screenshot_$.ext") and their meaning.helmut wrote:Is "Command line help" dialog in XnView what you are looking for? You open it using menu "Info > Command line help".
Furthermore I'd like to have even more parameters, like I said for example: command line parameters to fully configure the capture function.
best regards, Farbauti.
Farbauti
No answer from the developers is disappointing.
I still love the tool, but I'm in need of a command line that would start xnview automatically in capture mode with
- multiple captures option
- include cursor
- dest. dir
- screenshot filenames with date-time tag
- include cursor
- dest. dir
currently you can't make multiple capture, you have
to capture desktop in following filename (.ext is the extension, $ is time stamp)
-capture=desktop,d:\screenshot_$.ext
Farbauti
So, what you really want to say is, that this feature won't be implemented at all in the future...?xnview wrote:currently you can't make multiple capture...
Cheers, Farbauti.
oops66
Farbauti
No, sorry, doesn't work for me.oops66 wrote:... FI: Now you can (even with MP_0.66)...
http://newsgroup.xnview.com/viewtopic.p ... 82#p119382
Are you sure, we're talking about the same thing?
What I'd like to see is this:
I use XnView for making occasional screenshots. To be prepared, when I log in, I start xnview (via windows autostart along with other applications), but then I have to activate the screenshot functionality manually, as I need particular parameters (file-timestamp-format, multiple captures, include cursor, dest-dir, shortkey, ...). And sometimes I simply forget to activate this. I press the shortkey, and only later I find out, no screenshots were recorded
Thus I would really appreciate a funktion/opntion/parameter to automatically start XnView in (full configurable) capture mode.
Cheers, Farbauti.
oops66
Hello, ... Right, this not exactly meet your request, but a workaround is to use a script ... i use for this a script file (.bat with windows or .sh via linux) with the shortcut icon available onto my panel/desktop
To do a test first, maybe you can try into a Terminal (for windows) (run cmd)
or with date stamp:
xnview.exe -capture=desktop,c:\your_savedir\your_filename_###.jpgCode: Select all
xnview.exe -capture=desktop,c:\your_savedir\your_filename_$.jpg XnViewMP Linux amd64 -> Debian - MX - antiX
