Don't work: Add Text in Batch Convert Utility
Locked
zaudio
Post by zaudio »
Full patch: Tools - Batch Convert - Advanced Operations - Add Text
System:
Win2k Professional SP4
XnView 1.80 Final Freeware
RegArdZ
<Mail address has been removed by moderator - please see Rules and Guidelines>
Re: Don't work: Add Text in Batch Convert Utility
zaudio wrote:Full patch: Tools - Batch Convert - Advanced Operations - Add Text
System:
RegArdZ
Ok, :bugconfirmed: will be fixed in 1.80.1
zaudio
Post by zaudio »
xnview wrote: Ok, :bugconfirmed: will be fixed in 1.80.1
ThanX 8)
Ulf-A
Batch convert adv. options add text
Post by Ulf-A »
Hi!
I used the Add text option and saved my options in a script
and when I use the script the second time there is no text added.
Im using 1.80.1
Thanks for a great prog.
Best regards
Ulf Andersson
zaudio
Post by zaudio »
Confirm words of Ulf-A.
Add Text does not work when loading earlier saved script :(
zaudio wrote:Confirm words of Ulf-A.
Ok, i'll fix it
zaudio
Post by zaudio »
xnview wrote:Ok, i'll fix it
When?
When?
Soon, i'll release a 1.80.2 perhaps this week...
wouter
Post by wouter »
Desperately waiting for the :bugconfirmed: fix :shock:
Otherwise, great programme!!! :)
Best regards
Wouter
Re: Add Text does not work when loading earlier saved script
wouter wrote:Desperately waiting for the :bugconfirmed:
1.80.2 is likely to release in the coming week (15th - 21th August).
Locked
