Default Tab in "Edit IPTC" window
Sebastian
Post by Sebastian »
Hi everyone!
After upgrading to XnView version 2.00 I found that XnView has changed its behaviour in an aspect that is rather important to me: In older 1.9x versions, the "Edit IPTC" dialogue windows always opened with the "Caption" tab in focus. With the new 2.00 version, the dialogue opens with the same tab in focus, that was active when the window was closed before. :?
Since I'm pretty much used to press <Ctrl>+<i> and start entering the caption and description right away, I would like to have the old behaviour back. Is there any way to achieve this?
Best regards,
Sebastian
Re: Default Tab in "Edit IPTC" window
Ok, i'll add a settings
Sebastian
Post by Sebastian »
Thank you very much! :D
Best regards
Sebastian
Sebastian
Post by Sebastian »
Well, it's been a while... :wink:
After skipping a few versions, I just upgraded to v2.20. However, I can't find an option (at least not in the "Options" menu) to change the behaviour as described in the first posting. What am I missing?
Regards,
Sebastian
