Browser mode: "Tools" menu
Instead of...
Open
Open With >
View in Hex mode
Search...
Find similar files...
Export...
Batch processing...
Send by Email...
JPEG Lossless transformations >
Change timestamp...
Extract Movie frames...
Set as Wallpaper >
Batch Rename...
Compare...
Sequence Convert...
Plugin >
Options...
...it might be:
Open
Open With >
View in Hex mode
Compare
Search...
Search duplicates...
Export...
Send by Email...
Set as Wallpaper >
Capture screen...
Batch processing...
Batch Rename...
Change timestamp...
Sequence Convert...
Plugin >
Options...
Notes and thoughts:
- "Find similar files" was renamed to "Search duplicates".
- "Compare" must not have an elipsis "..." because comparison is done immediately.
- "Capture screen" does not really fit in here.
- We have a "Tools" and "Create" main menus. Perhaps it makes sense to introduce a "Selection" main menu and put all functions that do something with the selected files there.
- budz45 has posted a related topic which discusses main menus of XnView MP, see topic 'Some re-organizing of the top menu items for MP'.
- This might be the start of a long discussion. Given that other people agree, Pierre might move Batch processing and Batch rename closer next to each other for a start.
