canvas resize limit 10.000 pixels
dopadapo
Post by dopadapo »
When using canvas resize, I can not use more than 10.000 pixels (Height). Why is it limited ? Thanks.
Re: canvas resize limit 10.000 pixels
by your memory
dopadapo
Post by dopadapo »
By memory what ??? I have no problem when using GIMP to resize image height more than 10.000 pixels, even twice.
In XNview, there is a BUG in the canvas resize that limits the value to 10.000 pixels.
It seems that you did not try it before answering. Try it ! THE PIXELS VALUE.
It works for me, i can use a canvas resize of 10001
dopadapo
Post by dopadapo »
E.g. The original height is 15422.
Once I click the up arrow of Screen-Size, Height (pixel); then the value will change to 10000 and stuck at that value. Clicking the up-arrow or pushing up-arrow keyboard button will *not* make the value go higher.
dopadapo wrote:E.g. The original height is 15422.
Oh ok i understand
