it seems to me as though the 'Change timestamp'-tool (which is very handy btw.) could not be used on images in multiple folders at once. I tried to do so by selecting a folder in the browsers tree view, right-clicking on it and then selecting 'Show all files (recursive)'. If I now start the 'Change timestamp'-toll, everything seems to be normal, but nothing changes.
Can anyone of you reproduce this weird behavior and if so, could this please be regarded a bug worth fixing?
Thanks,
Tobi
'Change timestamp' incompatible with 'Show all files'
Tobi
Tobi
Re: 'Change timestamp' incompatible with 'Show all files'
Hi again,
I seem to have isolated this faulty behavior to large numbers of images. On my machine, the tool works for 1690 images, but not for 1839.
Tobi
Tobi
??? Really, in the range 1690-1839 you have not a file that can cause the problem??Tobi wrote: I seem to have isolated this faulty behavior to large numbers of images. On my machine, the tool works for 1690 images, but not for 1839.
Tobi
I don't know, it was a completely different set of images. None of the files was read-only and XNview did not prompt an error message.
Tobi
Tobi
could you send me your email? i would like to send a test version
