XnConvert 1.51 - "Never check for updates" doesn't stick
dadadata
Post by dadadata »
I am trying to develop some canned xbs files which allow everyone here to insert generic boilerplate IPTC strings that we need to cover certain circumstances.
Because one of the strings that is used as a keyword is #nosale, and 1.55 breaks that string, I rely on 1.51.
I asked about how to get rid of the "update" dialog that pops up when the app opens. I am supposed to change the settings so check for update = "Never."
I then resave the named xbs file. However, it appears that the "Never" setting resets itself to "Monthly" more or less at random even after that setting has been saved in a new file.
This may be a known bug which was fixed in 1.55, but I can't use 1.55 until the #nosale -> 0nosale bug is fixed.
Re: XnConvert 1.51 - "Never check for updates" doesn't stick
i'll update soon a version
