cannot open folder with € in the name like "W€ther". I assume there are other chars as well.
Thanks if cou can fix this!
unable open folder with € in name
Re: unable open folder with € in name
XnView doesn't support Unicode...
XnViewMP and XnConvert -- both under development -- are cross-platform with Unicode support and so can be used if they have the functions you need.
nobody123
ahh, ok, thanks for fast answer!
I'll try the MP-version.
