XNViewMP-053-32bit on Windows7
1. Can we have XNViewMP's Canvas Resize dialogue similar to the XNView's ?
I miss the "9-boxes-and-one-dot" to set the position. It is easier to use.
Also, the "Keep Ratio" position is wrong since it is also applied to "Print Size" ; not for the pixels only.
If I *uncheck* the "Keep Ratio", the next time I open the Canvas Resize dialogue (in the same session), I hope it is still unchecked. Currently it becomes checked.
Can we have preview small-window while resizing the canvas, so thatwe do not have to exit Canvas Resize dialogue to see the result ?
2. I can not find the option to hide/show menu bar (File-Edit-View….). Can we have "Ctrl+M" for that ?
3. I have Windows7 task-bar at the top of screen. If I use Ctrl+F11 (2 times), XNViewMP is not at its original position (until I manually resize its window by clicking the maximize button at upper right corner)
Thanks
XNViewMP-053 comment 1
Re: XNViewMP-053 comment 1
It is more intuitive and slightly quicker to use, if it could be provided easily.I miss the "9-boxes-and-one-dot" to set the position. It is easier to use.
One of the things I noticed when i started using XnView software was that setting often didn't persist the way I expected from using other software.
Of course, sometimes one wants a setting to persist and sometimes not, but in general more persistence would probably be an improvement.
Another thing I noticed when I started using XnView was the very useful levels function in a freeware software
