Can't change certain file type associations
C0080900
Post by C0080900 »
I have to use right click > open with > check box to always open with to force register/associate certain file types with XnView.
However, those file types won't display in XnView even though I click them and XnView opens.
.ico, .tiff, etc won't display even after methods mentioned above.
I've tried, but to no avail.
Default programs> Set your default programs > (Program name goes here) > Choose defaults for this program.
Default programs > Associate a file type or protocol with a program
Any help here?
XnView 2.00.0, my XnView settings are stored in the .ini under the XnView installation folder.
Also tried running XnView as Administrator.
Re: Can't change certain file type associations
Is it good for .bmp?
C0080900
Post by C0080900 »
xnview wrote:Is it good for .bmp?
I noticed a strange problem/pattern, though.
When double clicking the .ico images, XnView opens, but doesn't display the images. However, if I drag n drop .ico images into XnView, XnView displays the .ico images.
I recorded my problem with Problem Steps Recorder. It's an .mht file. Several browsers that can open .mht files: Maxthon, Internet Explorer 7/8/9/10/etc, Opera, Firefox + Mozilla Archive Format
Here is a link to the .mht file that was created with Problem Steps Recorder so that you may further investigate and get a better idea of my issue.
i don't understand in the previous screenshot, you have not .ico??
C0080900
Post by C0080900 »
xnview wrote:i don't understand in the previous screenshot, you have not .ico??
No, .ico isn't listed in that list no matter how many times I check.
sorry but i don't understand your problem?
You want to change extension that are in the list??
C0080900
Post by C0080900 »
xnview wrote:sorry but i don't understand your problem?
Yes.
When I double click .jpeg images, XnView shows nothing.
When I drag .jpeg images to XnView, XnView displays the images.
And yes, I want to change the extensions in the list to open with XnView.
C0080900
Post by C0080900 »
Nevermind, installing XnView 2.03 appears to have fixed my issue.
