Save selection as image shortcut
stefanqn
Post by stefanqn »
hi there,
is it possible to save the selected area as a new image/ jpeg? I'm aware that I can use shift+x, ctrl+shift+s,ctrl+z instead, but a single command/ shortcut would be a real relief for a stamp collector :)
Re: Save selection as image shortcut
You're asking if XnView has a keyboard shortcut to save a selection directly to an image file?
I don't know of one but would be happy to be proven wrong...
Are you familiar with macro applications such as AutoHotKey? They enable a series of key strokes to be recorded or programmed and a keyboard shortcut to be assigned to the recorded macro script, which should enable you to obtain the functionality that you need:
http://en.wikipedia.org/wiki/AutoHotkey
