When I open EXIF tab in image properties dialog and switch to some other app's window and then back to XnView, the tabs contents are not redrawed. Probably it is appears only after invoking "Copy to clipboard" context menu item in EXIF properties list.
XnView v2.00 under Windows XP SP3+ 32-bit
EXIF tab contents are not redrawed properly
CreativeWorld
