Multipage TIFF printed in mirror.
Tested on different printers and computers with v 1.99.6 and 2.00
Re: TIFF printed in mirror
yes will be fixed
markusb68
Version 2.00 is O.K.
Version 2.02 still prints multipage TIFF (FAX) files in mirror.
Website says: Download XnView 2.03 for Windows.
But Link http://download3.xnview.com/XnView-win-full.zip points to Version 2.02.
Best Regards
Markus
Best Regards
Markus
Really?? But it's fixed in 2.02. Could you send me a file that you print? And which print setttings do you have?markusb68 wrote: Version 2.00 is O.K.
It's the 2.03Website says: Download XnView 2.03 for Windows.
DOS386
> It's the 2.03
EXE is "2.03" and "2.1.0.0" (!!!)
"WhatsNew.txt" is not updated 202'724 2013-May-29 says "Nconvert v6.40 XnView v2.02"
NCONVERT is not updated ... still 6.35 ... there is no 6.40
Could you please fix the compiling process to make the releases more consistent? This type of problem is recently rather frequent than rare
Yes, not always easy to change that...DOS386 wrote: Could you please fix the compiling process to make the releases more consistent? This type of problem is recently rather frequent than rare
markusb68
confirm the XnView-win-full.zip is 2.03.
But it's not working (mirrors multiple page TIFF / FAX Files)
I'll PM Dropbox link for files and Settings...
BR
Markus
BR
Markus
rtsanderson
I have the same problem with C4 (Edmics Group 4) files. If I open and print an individual file, it prints OK but if I print from the browser, it's mirrored even though the thumbnails look correct. I have Version 2.03, Libformat 6.40.
yaunxn
This bug is still present on xnview 2.03, but it has nothing to do with tiff files per se, it only vertically flips black & white images when printing more than one image/file.
Color & grayscale images are printed OK. I have tried it with single page bw tiffs and pbms.
daropoi
Same for me, 2.03.
Print preview looks ok, but b&w (CCITT 4) always prints mirrored, no matter if multipage or not.
A 2.04 will available next week...
