Did Nconvert Support Pipeline
RyanBram
Post by RyanBram »
With more than 80 commands, I think currently NConvert become strongest alternative for ImageMagick. I use it for simplifying my task in converting large amount of image. Unfortunately not all option that I need available in NConvert that means I should use another program for doing it.
Did NConvert currently support pipeline processing? How to do that,? Because I couldn't found it in the manual or main site.
Regards,
RyanBram
Re: Did Nconvert Support Pipeline
Why do you want to use pipe?
RyanBram
Post by RyanBram »
xnview wrote:Why do you want to use pipe?
Because NConvert support many format, but cannot perform pixel art scaling just like Image Resizer. Image Resizer can perform pixel art scaling but didn't support many format. I just want to do my task in simpler way by combining both program (NConvert for converting, imageResizer for pixel scaling).
Thanks.
