Uninstall?
Nili
Uninstall?
Post by Nili »
Hi!
I'm running 0.50 Beta on Linux Mint 14
Installed as .deb 32bit from this page but now, i want to remove and try 0.54 when it released.
Please could you tell me how to remove the beta?
Thanks a lot.
I've tried :
[nili@linuxmint]$ sudo apt-get remove xnview
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 16.4 kB disk space will be freed.
Do you want to continue [Y/n]?
I am afraid that is not correct, 16.4 kB The package size looks less.
Edit: uninstalled successfully with "sudo apt-get remove xnview" then removed .xnview from /home/
Regards,
Nili
typhoon71
Re: Uninstall?
Post by typhoon71 »
May be of interest: if you kept the .deb of the package you installed, and you hapen to have gdebi, you just doubleclick on it again and press the remove button.
