Love the viewer! But folder tree loads really really slow, same thing on 4 computers with latest version. Were talking 40 folders with around 1000 images in earch as a test bed and it's the same on each and every client.
If folder tree view is disabled everything else is fast.
Is there a bug somewhere that makes folder tree view attempt to load thumbnails based on the content of each folder even though they have been turned off?
How can i fix this?
Folder Tree Loading Slow, why?
Re: Folder Tree Loading Slow, why?
With last version?
d4rk0n3
Yep running latest version
Version 2.00
Libformat Version 6.35
Keep up the good work, from all image softwares yours is still the best, i find most features i want and its very clean once you've set it up!
Version 2.00
do you have same problem with other software?
Which OS?
Which OS?
