Controlling JPEG compression?
gabpbar
Post by gabpbar »
Hello, I'm using NConvert to convert wdp images to jpg images.
Here is an example of the conversion commands that I'm executing.
"C:\Program Files (x86)\XnView\nconvert.exe" -out jpeg -truecolors -o C:\FTP_Transfers\28763549.jpg C:\FTP_Transfers\28763549.wdp
My reason for converting to jpg is not to save on space, it's just to make the file viewable in a standard browser. I would like to have the image quality be reduced by as little as possible during the conversion.
Myt question is... Is there a way to control how much compression is performed when converting from wdp to jpg?
Thanks,
Gabe
Re: Controlling JPEG compression?
In the command line options for nconvert :
-q value : JPEG/PNG/FPX/WIC/PDF quality (default : 100)
A full listing of the command line options for nconvert can be obtained from :
"C:\Program Files (x86)\XnView\nconvert.exe" -help | more
Or more usefully can be redirected to a txt file.
This would be better posted in the NConvert section of the forum...
oops66
Post by oops66 »
... You can check the quality with imagemagick too.
http://www.imagemagick.org/script/identify.php
identify -verbose a.jpg | grep Quality
  Quality: 85
gabpbar
Post by gabpbar »
Thanks. I did look at the help, but I missed that option. Worked like a charm.
One strange thing that I did notice is that the default when you run the conversion without specifying the -q option is not actually 100. It seems to be 85 and if you specify the -q option and don't specify a value then the default seems to be 1.
Regards,
Gabe
