The Information Panel (the one which holds the Properties, EXIF, Histogram aso.) isn't resized properly when one drags the splitters. In fact, the dimensions of the panel stays the same with the ones from the beginning (ie. the original dimensions which the panel had when XnView started). The layout which I use is quite similar with FastStone Viewer or ACDSee (ie. with the Information Panel on the lower-left corner, Navigational Trees on the upper left and the Thumbnails on the right).
Perhaps it is worth mentioning that I have the Preview on the 2nd monitor.
Implementation considerations:
Obvious. Resize that Tab/Page Control as a response to splitter's move. Usually it should do it "automagically" but it seems that it needs some code in there.
Info Panel (Properties, EXIF etc.): not resized properly
m.Th.
m. Th.
