0.53b win64 - Default theme is not the default
thany2
Post by thany2 »
The theme I started xnviewMP with for the very first time, is not what is in the program called "Default". In fact, the theme it initially started with, is nowhere to be found. I found it rather more pleasing than all the others, which (admit it) look archaic at best. I would love to get the *default* theme back, which isn't the "Default" from the menu.
Using Windows 10 21H1 and loving it. Cheers!
Re: 0.53b win64 - Default theme is not the default
Which theme do you have? could you post a screenhot?
thany2
Post by thany2 »
Well, I *was* using whichever theme was enabled upon a fresh, clean, blank setup. Never had this program before on my computer. So whichever theme is selected on a virgin installation, that's the one I was using.
Then, I selected a couple of other to see what they are. Turns out I don't fancy any of them, and wanted to go back to the default. But selecting "Default" shows a different theme than the theme it initially started with, when it was still a virgin/blank/clean/fresh setup. None of the other themes match, either.
Default use windows theme
