delete space from result name
bunak
Post by bunak »
Hi
I do batch convert images to png. But some source images have space in name (for example "1233 .bmp"). Is it possible delete/remove space from name when NConvert convert it (to "1233.bmp")?
Now my command look like this
nconvert.exe -D -out png *.*
after finish converting i use cmd scripts for remove space from names.
FOR /R d:\Project-Result\Img %%f IN (*) DO CALL:REN "%%f"
goto:eof
:: :REN    - subfunction
:: %~nxI   - expands %I to a file name and extension only
:REN
set "file=%~nx1"
ren %1 %file: =%
But, it is Better if space will remove when NConvert converting images.
oops66
Re: delete space from result name
Post by oops66 »
FI: ... For me, it's better to replace spaces in filenames with underscores. (for readability)
bunak asked:
Is it possible to delete/remove space from name when NConvert convert it (to "1233.bmp")?
I don't think so.
But as NConvert can process a folder of images, maybe a batch file .bat that first calls NConvert then calls your cmd.exe script?
Note: No spaces in paths allowed if wildcards are used in file names.
