NEF to JPEG conversion...need equivalent NConvert parameters
StartledLemon
Post by StartledLemon »
I have a number of NEF files taken with my Nikon D7000 that I would like to convert to JPEGs for archival. XnConvert performs the conversion perfectly using all the default options, but NConvert darkens the picture considerably (see the screenshot I will upload as an attachment).
I'm using the following to perform the NConvert conversion on my Win7 x64 machine:
nconvert -out jpeg -o %_NConvert *.NEF
I've tried using the 'Export for NConvert' button in XnConvert but all I get is a batch file with the single word 'nconvert' in it.
Can someone tell me where I am going wrong? How do I get the same output JPEGs from NConvert as I do from XnConvert?
Kind regards,
/Neil
Re: NEF to JPEG conversion...need equivalent NConvert parame
could you send me the nef file and the result from xnconvert & nconvert, please?
StartledLemon
Hi Pierre,
Thanks for your prompt reply. The NEF files are quite large (~20MB each). Shall I PM you links to the files on my Dropbox account?
Kind regards,
/Neil
StartledLemon wrote: Thanks for your prompt reply. The NEF files are quite large (~20MB each). Shall I PM you links to the files on my Dropbox account?
yes please
StartledLemon
Hi Pierre,
I have sent you a PM with a link to the Dropbox folder containing the files. Please let me know if you don't receive the PM.
Kind regards,
/Neil
Ok, XnConvert extract embedded jpeg by default, i'll add such option in NConvert
DOS386
Post by DOS386 »
xnview wrote:XnConvert extract embedded jpeg by default
So XNConvert extracts instead of converting ... and NC converts but causes brightness loss ?
Good idea, but this won't fix the lib conversion / NEF decoding bug, nor the XNConvert export batch bug ?
IIRC I had problems with NEF decoding in the past, no tests recently.
