0.56: Menu View -> Info Pane needs entry show
herb
Post by herb »
I work with version 0.56 of XnViewMP.
I did a mistake and closed the Info Pane. Now I had the problem to make it visible again.
I my case "Restore Layout A" solved the problem. But an entry in menu would be more than helpful.
So please add "Show" to menu "View" --> "Info Pane".
Such an entry is available for Tree Pane, but is missing for Info Pane.
Best regards
Herb
oops66
Re: Menu View -> Info Pane needs entry show
Post by oops66 »
... You have: View\Info Pane\Use Tabs ?
