Currently, the default behaviour of XnView MP 0.56 and XnView Classic differ regarding the mouse control:
XnView Classic:
- Mouse wheel: Zoom in/out
- Ctrl+Mouse wheel: No action
- Left mouse button: Select area
- Right mouse button: Grab image for moving
XnView MP 0.56:
- Mouse wheel: Navigate previous/next image
- Ctrl+Mouse wheel: Zoom in/out
- Right mouse button: Select area
No grabbing for moving image
The missing grabbing to move the zoomed image around is really a big lack in functionality and should be added soon. Or did I miss something?
Unify XnView Classic and XnView MP
The above mouse support of XnView Classic might not be standard (e.g. Ctrl + Mouse wheel zooms in most applications whereas in XnView Classic it does nothing), but I'm very much used to this behaviour. And I guess other users are also used to this behaviour. O.k., users (including me) can learn and get used to a new behaviour, but currently XnView Classic and XnView MP differ which makes switching between the two applications confusing and more difficult than needed.
I'd suggest:
a.) Discuss and find a useful and handy default mouse behaviour
b.) Change both XnView Classic and XnView MP to that default mouse behaviour and thus unify mouse behaviour.
Mouse control: No grab hand and difference between platforms
oops66
Re: Mouse control: No grab hand and difference between platf
...+1, ...Yes, maybe it's the time of an harmonization (labels, mouse ctrl, etc...) during this beta stage ???
XnView(MP) menus need to be "standardized"/simplified too:
http://newsgroup.xnview.com/viewtopic.php?f=60&t=28143
budz45
Hi helmut,
Well yes I agree with you somewhat.
In XnViewMP I always have enabled the 'Right mouse button' for grabbing (Pan) of pictures
Regarding the default behaviour of the 'Mouse wheel' - I think Pierre went for the IrfanView approach of having the mouse wheel navigate through pictures instead of zoom in/out because maybe he found a consensus of users that preferred this approach. Personally I prefer the default mouse wheel for Zooming. Thankfully all of this is customizable within XnViewMP.
Right button = Move picture
Right button + CTRL = Move picture
This is why the configuration model in XnViewMP is so much more better and updated than in XnView Classic
Well yes you can enable that, I have these set as these: (XnViewMP 0.56 --> settings>keyboard/mouse)helmut wrote: No grabbing for moving image
Thank you, oops66 and budz45 for your support and feedback in this matter! With the right settings in XnView MP this works like a charm.
I don't mind if the default behaviour of XnView is changed. But it should be well thought through beforehand and then it should be changed in in both XnView MP and XnView classic at about the same time.
sunnyimran
Re: Mouse control: No grab hand and difference between platforms
I need am trying to find same functionality in xnviewMP 0.93 !
Please someone tell me how can I configure such that for Panning larger images I have to just move mouse and image moves accordingly. I have seen such functionality in other viewers.
waiting
waiting
