Import Settings from XnView Classic
Elmer BeFuddled
Post by Elmer BeFuddled »
Hi all, first post.
Just discovered MP after years of using xnView.
Is it possible to use my xnview.ini as a direct import to the xnviewMP folder to replace its .ini file?
Be easier than manually inputting the settings!
TIA. Elmer
Apologies if I dropped this in wrong forum, I can't find me glasses (or a certain wabbit!!)
