Folder sorting in detail view
lolewi00
Post by lolewi00 »
In the original XnView for Windows, when I select a column in detail view both folders and files in the current directory are arranged based on the selected column, but folders are still listed before files as usual. In XnViewMP on both linux and Windows, I can only get both files and folders to sort based on the selected column by choosing mixed file and folder sorting. When I use normal sorting (folders before files), only files sort based on the selected column. Folders stay sorted by name. Is there any way to get XnViewMP to sort folders by date or another column in detail view without using mixed file and folder sorting. If not, would you please consider adding that function to XnViewMP as it is in the original XnView. Thanks.
Re: Folder sorting in detail view
it's a bug, date must be used for folder when sorting by date
lolewi00
Post by lolewi00 »
Ok. Thanks for the confirmation and the quick reply.
