I work with XnViewMP 0.56 on a windows system.
A *.jpg image has the ExifImageWidth/Height: 3072/2048.
After rotating this image 90° clockwise the values of ExifImageWidth/Height are exchanged to 2048/3072.
But rotating the image 90° counter-clockwise the values of ExifImageWidth/Height are not changed.
For me this is a bug to be corrected.
Best regards
Herb
0.56 - Error after rotating image
Re: 0.56 - Error after rotating image
could you send me the file?
herb
Hello Pierre,
attached please find such a file. After you have rotated this image 90° counter clockwise ExifImageHeight/Width are not changed
Best regards
Herb
Best regards
Herb
herb
Hello Pierre,
could you reproduce the problem?
Is it a general one, or does it happen only with my images?
Best regards
Herb
Best regards
Herb
yes will be fixed
