'Scan File Headers in folders' set to ALWAYS. Recognize only by extension is OFF.
1. In list view, no sorting/screening occurs when directory is refreshed. All files are listed, even non-displayable ones. In every other view, files are sorted and screened according to preference.
Fixed. v.1.80.2RC
2. Files without extensions are handled differently by viewer and browser. When advancing through a directory of files, the viewer does not see files without extension (tabs and standard fullscreen). The browser sees them (preview fullscreen).
Fixed. v.1.82
[Fixed]Handling of files with no extensions
Re: Handling of files with no extensions
Same with PDF files, in standard FS and Viewer PDF files are skipped, but in FS lite (preview fullscreen) there is a blank screen on PDF files (all "PDF" options are disabled).marsh wrote:2. Files without extensions are handled differently by viewer and browser. When advancing through a directory of files, the viewer does not see files without extension (tabs and standard fullscreen). The browser sees them (preview fullscreen).
Dreamer
