0.56 Win 7 64 bit double click on image ->viewer empty
saturn
Post by saturn »
Hi all,
in version 0.56 there is a problem at double clicking on an image in Explorer, the viewer doesn't show the
affected directory - it is always the same, even if i change the prefences
in v 0.53 it worked proerly
I added a short video here:
http://www.vidup.de/v/7KzXt/
OS:
WIN7 64 Ultimate bit
greets, saturn
Re: 0.56 Win 7 64 bit double click on image ->viewer empty
In your video, the viewer is not opened???
saturn
Post by saturn »
correct - it doesn't open the viewer in the "double clicked directory" nor the fullscreen display.
as mentioned in v0.53 when i double clicked a image it was opened in fullscreen
i tried to join the file extensions another time but it didn't help
greets, saturn
could you try with a clean .ini?
saturn
Post by saturn »
i started with a empty .ini,
then xnview MP started in C:\Users\***\Pictures\
even if i double clicked on the file in a different directory ......
greets, saturn
it seems that you have a problem in the association...
saturn
Post by saturn »
xnview wrote:it seems that you have a problem in the association...
That's right:
The solution was:
To unregister all assosiation with "Associate files with XnViewMP.exe"
If i associated with this exe, the same matter occured :?:
But if i registered via Windows then it worked (i did with jpg)
and then if i try the "Associate files with XnViewMP.exe" again, look
the jpg checkbox is deactivated
so i think i have to associate all extensions step by step...
greets, saturn
