Always (Copying...)
m.Th.
Always (Copying...)
Post by m.Th. »
Do you know what I did in the following window?... :D
Yes, I did a "MOVE To"... :D
However, XnViewMP always says '(Copying...)'. I know, a small thing...
but perhaps is better to be fixed.
m. Th.
budz45
Re: Always (Copying...)
Post by budz45 »
Well spotted! :) Should get fixed soon
m.Th.
Post by m.Th. »
1. Bump! :)
2. Pierre, if you can put the correct caption (ie. (Moving...) when is moving and (Copying...) when it is copying) at least put something neutral like Transferring...
3. It is Issue 134 :)
m. Th.
m.Th. wrote: 2. Pierre, if you can put the correct caption (ie. (Moving...) when is moving and (Copying...) when it is copying) at least put something neutral like Transferring...
Yes not easy, i use a QT component, i'll change for transferring
m.Th.
Post by m.Th. »
Aha! I understand you and I support your decision.
m. Th.
