"Invisible" Folders for the Batch Convert
m.Th.
Post by m.Th. »
In the following configuration... :D
Select 'Folder 1' and, if you want, 'Folder 2'. Just to make sure that you do not select any file.
Press Ctrl+U or select Batch Convert from the menu. You'll see in the list 0 (zero) files. :shock:
Also, if you want, select some folders (with photos inside) an one-two files. You'll see that in the Batch Convert only files appear.
The selected folders are invisible for the Batch Convert engine.
m. Th.
