View | Fullscreen | Options | Show Information. Using string:
<Directory><Filename> <Shutter Speed>s f/<F-Number> ISO<ISO Value> FL <Focal Length>mm
But shutter speed is visible if you click on the EXIF tab in Browse, or use the Custom 1 thumbnail label variable:
Dan.
