I dont understand how to install or use XnView MP for Windows 7 64bit. The downloaded directory contains no setup.exe or else. If I doubleclick the xnview.exe it says it is needed a Side-by-Side configuration.
Greetings
lutfi9
How to install/use XnView MP on Windows?
Re: How to install/use XnView MP on Windows?
Double click on .exe, that's all.
Perhaps you need to install THIS
lutfi9
Thanks. But like I said, if I double click on xnview.exe it says something about Side-by-Side configuration ist not valid. Why is there no setup file?
Do you have installed the CRT?
lutfi9
Yes, now it works after installing the CRT. I didnt wanted to install before I knew it is really needed. But strange why there is no instruction manual or a setup possibility like XnView Standart.
Thank you very much.
Greetings
lutfi9
Greetings
lutfi9
