XNViewMP 0.56 beta
View -> Details (with EXIF "Comment" column active)
1. Select JPG file(s), then press ^D (Set comment...)
2. Modify embedded comment and press [Write]
3. Comment is now correctly changed and updated
4. Press ^D again, modify Comment again, all OK, works fine in JPG files
1. Select TIFF file(s) and modify comment same as previous on JPG
2. Column "Comment" report NEW comment, but...
3. Press ^D again: old comment is displayed forever
See EXIFTools and XNViewMP Propertied tab for changes.
DNG files not investigated, but perhaps report same problem.
EXIF update error in TIFF file
Re: EXIF update error in TIFF file
'Embedded comment' is only supported by JPEG currently...
ooo.ooo
IPTC is anyway considered "standard" field?
Can I use IPTC "Caption" and others fields?
TIA
TIA
IPTC works on TIFF/JPEGooo.ooo wrote:IPTC is anyway considered "standard" field?
TIA
mahikeulbody
Well, IPTC is not exactly the name of a standard, it is a name of the organisation (International Press Telecomunication Council) which manages the standard about press metadata (which include photo metadata). By extension, their previous standard was often called IPTC but the exact name was IPTC-IIM. But since a few years the new IPTC standard is IPTC-XMP based on XMP format (from Adobe) and IPTC-IIM is being (slowly) deprecaded. XnViewMP is able to manage both and, in most cases, to synchronize both but the IPTC recommendation is to use IPTC-XMP.ooo.ooo wrote:IPTC is anyway considered "standard" field?
TIA
