Request: Bold frame in the file select
tehbo
Post by tehbo »
Request:
I hope to be able to set the bold frame in the file selected. :)
The thin frame, visibility is not good. :(
m.Th.
Re: Request: Bold frame in the file select
Post by m.Th. »
tehbo wrote:Request:
Try to change the Border Size in Tools | Settings | Thumbnail | Appearance
m. Th.
tehbo
Post by tehbo »
Thank you.
But, I hope change the size of the default blue color border.
m.Th.
Post by m.Th. »
tehbo wrote:Thank you.
Aha! I see now.
...for me is rather ok because I look mostly at the file names which are highlighted with a different color (blue) which is quite different from the dark color of the non-selected thumbs.
m. Th.
m.Th.
Post by m.Th. »
Aha! I see now.
Hmmmm...
In fact, I kinda support this. Sometimes, especially if the thumbs are small, isn't so visible. And I think that besides of pen width it should be also configurable the pen color. Hence something like this:
Selected thumbnail:
  Border Width [___1]
  Border Color [ "Orange" v]
m. Th.
tehbo
Post by tehbo »
That's right! :D
