other small text-improvements for 'Properties'
budz45
Post by budz45 »
This topic is a very small request. :)
I'm running XnViewMP 0.60 on Win 7 x86...
...These are my screenshots...
1.)
1.) The same hyphen (GUI) used in "Date taken" should be used for the fields for the Creation date/time, Modified date/time and Accessed date/time. The hyphen being "-" to go in between the date and time.
2.)
2.) It would be nicer if the "File size" text was written with the unit-coded filesize text first as a prefix to the cumulative filesize text which would be encased in brackets. So in the case of the second screenshot it would be better if it was laid out like this:
File size      385.2 KiB (395,084)
m.Th.
Re: other small text-improvements for 'Properties'
Post by m.Th. »
...or, perhaps, better to provide some format strings for Date/Time constants?
...also for file sizes the program already shows in the main status bar using 'smart' formating, taking in account the file size and the the Settings | Browser | Browser > "Show always in bytes the file size" checkbox (disabled by default). Perhaps is better to use here the same formatting engine?
m. Th.
budz45
Post by budz45 »
It's got nothing to do with custom formatting. These are just small permanent enhancement changes for gui.
m.Th. wrote:...also for file sizes the program already shows in the main status bar
That's like saying to me that the "image resolution and image filename are already in the status bar, so go on look there too". It is a weak argument. Remember I am simply requesting the filesize to get reinterpreted a bit better.
Here's another example:
So from this screenshot, the 'File size' in "Properties" dialog should be better GUI reinterpreted like this:
File size      1.92 MiB (2,010,211)
It would still be the same just both kept together. The status bar would always remain the same.
m.Th.
Post by m.Th. »
budz45 wrote:It's got nothing to do with custom formatting. These are just small permanent enhancement changes for gui.
No, I don't say to "...go on look there too". I say to Pierre (NOT to you) to use that formatting code in order to fulfill your request. IOW, to use the same procedure/method/whatever here in the same way in which he used it in the status bar. Reread what I wrote in my first post:
Am I clearer now? :)
m. Th.
budz45
Post by budz45 »
Ok sorry about that, yes your clearer now and thanks for supporting this request. :)
budz45
Post by budz45 »
Thank you. Fixed in XnViewMP 0.61 :)
