Hello Pierre,
Some weeks ago I opened a topic with problems in case of rotating images.
Now I retested your correction in XnViewMP 0.60.
The specific image I talk about, is an image which was rotated clockwise and counter-clockwise very very often - and maybe it was used for also other tests.
It was rotated with XnViewMP 0.56 and also with XnViewMP 0.60.
Now when I display the folder that contains this image - in preview it is displayed in landscape - the thumbnail is displayed in portrait.
I select this image and open e.g. the settings dialog.
Now when I close this dialog or atleast when I reopen the settings dialog XnViewMP crashes.
XnViewMP 0.56 and e.g. also IrfanView has no problems with this specific image.
Because of the size of the image I will send it via mail to your contact mail-address.
I am sure you can also reproduce the crash on your system.
Thanks for your investigations in advance.
Herb
0.60 - crash with specific jpg image
Re: 0.60 - crash with specific jpg image
If you have only this picture file in a folder, same thing? If yes, could you send me it...
herb
Hello Pierre,
yes XnViewMP crashes also in case of only this image is inside a directory.
I sent this image on 6.7. Please tell me in case of I have to send it again.
Best regards
Herb
Best regards
Herb
on my email?
herb
Hallo Pierre,
it looks like that you did not get my mail on 6.7.2013.
So I sent it again to contact (at) xnview (dot) com. Title is :Topic: 0.60 - crash with specific jpg image
Best regards
Herb
Best regards
Herb
ok, right
herb
Hello Pierre,
thanks for the corrections with version 0.61 of XnViewMP. I cannot reproduce the crash anymore.
By the way, do you remember whether it was a more general problem in XnViewMP or was it very specific to my image?
Best regards
Herb
Best regards
Herb
