I Can No Longer Directly "View in Fullscreen" (F11)
viking
I used to be able to view an image in Fullscreen mode directly from the Browser window by simply clicking F11 or right-click on the file name and then select "View in Fullscreen". However, lately nothing happens when I do this. The only way is to hit Enter (or select "Open") followed by F11.
I am using v 2.00 and it used to work fine in this version (I have same issue in v 1.97.8 )
Peter2
Re: I Can No Longer Directly "View in Fullscreen" (F11)
I just tried F11 from the browser and context menu from browser - everything OK for me.
Have you checked all your settings? Tried to work with standard configuration?
Peter
Peter
viking
Yes & Yes (and also downloaded and "installed" a fresh portable version)Peter2 wrote:I just tried F11 from the browser and context menu from browser - everything OK for me.
Peter
oops66
... And a middle mouse click on thumbnail from the Browser Mode ?
(Options\Switching Mode)
Use middle click to switch between:
Browser <> Fullscreen | Viewer <> Fullscreen XnViewMP Linux amd64 -> Debian - MX - antiX
viking
It also does not work....oops66 wrote:... And a middle mouse click on thumbnail from the Browser Mode ?
(Options\Switching Mode)Code: Select all
Use middle click to switch between: Browser <> Fullscreen | Viewer <> Fullscreen
Note that right-clicking and selecting "View in Fullscreen" also does not work, and that should always work.....
There is something more fundamentally wrong as I sometimes also see no preview in the Browser until I click F11; I will then see the preview in the Browser (but again no full screen).
I think that the troubles may have started after a Windows update (which also updated the video driver). I later updated the video driver to the absolute latest version, but it made no difference.
p.s. I am using WIN 7 64 bit
viking
I am still trying to solve this issue. I now tried using msconfig;
I got F11 to work if I boot in Safe Mode (= Safe Boot).
However, it does not work if I use "Diagnostic Startup" or "Selective Startup" (disabling startup items and system services).
XnView is the only program that started to give me problems since my Windows Update (which may have been the cause of the problem).
Strange, could you try with a clean xnview.ini?
viking
That was the first thing I tried; A new "installation" of the portable version with xnview.ini in the portable directory. Didn't help.xnview wrote:Strange, could you try with a clean xnview.ini?
I just tried it again. Deleted the xnview.ini in the portable directory => xnview came up with the configuration wizard. Still same issue though..
Peter2
Some years ago a standard problem with shortcuts was caused by "ATI Drivers for Monitors". It took a lot of shortcuts and overwrote them. But it is not a really possibility ...
Peter
Peter
viking
This is not related to any shortcut issue since it also happens when I right-click and select "View in Fullscreen".Peter2 wrote:Some years ago a standard problem with shortcuts was caused by "ATI Drivers for Monitors". It took a lot of shortcuts and overwrote them. But it is not a really possibility ...
Peter
"View in fullscreen" doesn't work too?? And in view mode same problem?viking wrote: This is not related to any shortcut issue since it also happens when I right-click and select "View in Fullscreen".
Drahken
Have you tried the MP version of xnview to see if it behaves the same way? Regardless whether it behaves the same or differently, KNOWING whether it behaves the same or differently might help narrow down the source of the problem.
viking
Correct, "View in Fullscreen" also doesn't work. It works fine in View Mode.xnview wrote:"View in fullscreen" doesn't work too?? And in view mode same problem?viking wrote: This is not related to any shortcut issue since it also happens when I right-click and select "View in Fullscreen".
As I wrote originally in the first post above: "I used to be able to view an image in Fullscreen mode directly from the Browser window by simply clicking F11 or right-click on the file name and then select "View in Fullscreen". However, lately nothing happens when I do this. The only way is to hit Enter (or select "Open") followed by F11."
(I believe that I am in "view Mode" after I hit Enter or select "Open"?)
viking
What is MP version? The regular installation version? I prefer not to install anything more if I can avoid it... If Pierre really thinks that it would help, I could do it though...Drahken wrote:Have you tried the MP version of xnview to see if it behaves the same way? Regardless whether it behaves the same or differently, KNOWING whether it behaves the same or differently might help narrow down the source of the problem.
Drahken
The MP version is a version of xnview that's designed to be cross-platform.
http://newsgroup.xnview.com/viewforum.php?f=60
download links: http://newsgroup.xnview.com/viewtopic.php?f=60&t=28289
