0.60 win-x86: Synchronize Browser setting not working
budz45
Post by budz45 »
In XnViewMP 0.60
When I disable "Synchronize Browser when view is closed"
The setting is now not working when I disable it in MP 0.60.
I test it by opening an image in view mode and double-clicking on the image to open the Browser.
When disabled it is supposed to work by using my last used folder-directory of the Browser and not the folder-directory of the image file from view.
Pierre, my INI is available if you want to test with it.
Re: 0.60 win-x86: Synchronize Browser setting not working
When you close a view, folder in browser view is changed??
budz45
Post by budz45 »
xnview wrote:When you close a view, folder in browser view is changed??
No I mean when I double-click on the pictured in View to switch to Browser...
...While the setting "Synchronize Browser when view is closed" is disabled.
It's the same in previous version, no change here. The setting is only when you close view tab
budz45
Post by budz45 »
Right I see... :)
So the setting is for 'when view is closed' and not for when 'view is switched'.
Ok Understandable.
