Cant use embedded Comments in JPG's
Acantiming
Post by Acantiming »
I have downloaded today XnView Small Package for Windows. If i try to enter a comment it seems, that i cant save this. If i enter a comment and save it, i cant see this comment in WIndows Explorer, if i look at the propertys, the comment is empty. Do i make something wrong?
Re: Cant use embedded Comments in JPG's
and you see it in XnView?
Acantiming
Yes. I see the Comment in XNView. If i add a comment in Windows Explorer, i could also see the Comment in XNView. I have found it under EXIF > XPComment. Additonaly i found another Problem, but thats not so important. On Work i use a Tool named "Hardcopy". This saves a embedded Comment in the *.jpg files. This comment has more than 1 Line. XnView displays only the first line, the second line isnt visible. If i try IrfanView, i can see all the Lines (but i doesnt like IrfanView).
bilbo_b wrote:Yes. I see the Comment in XNView. If i add a comment in Windows Explorer, i could also see the Comment in XNView. I have found it under EXIF > XPComment. Additonaly i found another Problem, but thats not so important.
Ok, Windows explorer use EXIF>Comment, XnView use JPEG>Comment
could you send me a test file?
Acantiming
Is it possible to sync JPEG>Comment to EXIF>Comment via XNView?
xnview wrote:
bilbo_b wrote:On Work i use a Tool named "Hardcopy". This saves a embedded Comment in the *.jpg files. This comment has more than 1 Line. XnView displays only the first line, the second line isnt visible. If i try IrfanView, i can see all the Lines (but i doesnt like IrfanView).
I have attached a Testfile for you and hope its not changed after the upload :-) There schould be a comment "LEAD Technologies Inc. V1.01" with a second line
bilbo_b wrote: Is it possible to sync JPEG>Comment to EXIF>Comment via XNView?
No :(
ok, thanks, i'll check
