0.60: Shortcut setting "Fit image to window" in Browse mode
quapurna
Post by quapurna »
XnViewMP 0.60
Windows7 32
Xubuntu1304
Halo.
In Browse mode:
Menu > View > Preview > Auto Image Size > Fit image to window "/" .
The keyboard button "/" is used as its shortcut.
I want to use that button for zoom-100%, but I do not know how to do so because in the option:
Settings > Interface > Shortcuts > Browse mode
there is no option to modify shortcut for all "Fit image to window…" in Browse mode.
They are available for View mode only.
Thank you.
oops66
Re: 0.60: Shortcut setting "Fit image to window" in Browse m
Post by oops66 »
quapurna wrote:...I want to use that button for zoom-100%...
... For 100% zoom try the keyboard button "*" - shortcut.
quapurna
Post by quapurna »
Thanks.
I know that default one.
On my laptop, I have to use "Shift 8" or "Fn P" to get * since there is no single button for *.
I try to avoid using two buttons (combination).
I want to use "comma", "dot", "slash" for zoom-out, zoom-in, 100% respectively since there are closer.
Perhaps, I should try [ ] and \ .
Back to the issue, can you change/remove the shortcut "/" from the command "Fit image to window" for Browse mode?
m.Th.
Post by m.Th. »
Thanks.
Istm, you cannot. Perhaps is better to ask Pierre to add it to the the shortcuts list. There are also other key combinations missing...
m. Th.
quapurna
Post by quapurna »
Halo, m.Th.
Thanks for the confirmation.
I thought it was only on my laptop.
I hope Pierre has read this thread.
Thanks.
Why you can't change default key for 'zoom 100%'??
m.Th.
Post by m.Th. »
xnview wrote:Why you can't change default key for 'zoom 100%'??
Istm the OP is asking about "Fit image to window" in Browse mode - the "/" shortcut which isn't present in the Shortcuts table (not about 100% which is indeed the '*')
And because we're here can you add there the following shortcuts?
Rate 1 Star
Rate 2 Stars
Rate 3 Stars
Rate 4 Stars
Rate 5 Stars
...the industry standard is to have to these commands assigned the keys '1', '2', ... '5'.
The same stands for the colors:
Mark Red
Mark Yellow
Mark Green
Mark Blue
Mark Purple
...and a very very very useful idea from Lightroom are the "... & Next" shortcuts:
Rate 1 Star & Move to next image
Rate 2 Stars & Move to next image
...aso.
m. Th.
quapurna
Post by quapurna »
Halo, Pierre.
As m.Th has confirmed, I want to remove the shortcut "/" from the command "Fit image to window" in Browse mode (Preview pane).
I want to use "/" for "Zoom100%"
Further Question:
If a shortcut has been assigned for a command (default or custom) and then you assign the same shortcut for another command, how XnViewMP should behave?
Should the older assignment be automatically aborted and the shortcut be assigned to the new commad ?
Should a confirmation appear for this condition ?
Thanks.
m.Th.
Post by m.Th. »
In the worst mode possible: Neither the first neither the second command will work anymore.
In order to make things work again, you must:
1. Remove all but one the conflicting shortcuts
2. Restart the program
From usability POV, this can happen only when we have layered keyboard shortcuts. Here we'll have, I hope, for the keywords / categories.
Dictionary:
layered keyboard shortcuts = the current keyscan combination is searched first in the shortcuts table for categories and if no match is encountered, then it will be searched in the lower layer (the actual layer for Browse mode).
But also in this case a message saying...
The shortcut "Ctr+Bar" hides the same shortcut for the command "Baz".
    {Ok}
...it would be a very welcomed addition.
But if we speak about the same keyboard layer (IOW two shortcuts conflicting in the Browse mode) then nope. It is a human decision. The program must inform you even with a simple...
The shortcut 'Ctrl+Foo' is already assigned to the command "Blah".
Do you want to remove it from there and assign it here?
                               {Yes}  {No}
Yes, IMHO - see above.
To be fairly sincere, there are programs which automagically hide all but one shortcut but then it is a little bit fuzzy which command is run (IOW which shortcut win). Sometimes the one which wins is the latest shortcut, in other programs is the one which has the command first in alphabetical order (ie. the lookup list is sorted alphabetically by cmd name), and in others the list is simply unsorted and the first cmd wins.
m. Th.
quapurna
Post by quapurna »
Thanks, m.Th, for the clear explanation.
I see that VLC popups a good warning dialogue for that condition.
e.g. I try to set "f" for "Faster" while "f" is already assigned for "Fullscreen"
(dialogue title)
"Hotkey for Faster"
(dialogue contents)
Key: f
Warning: the key is already assigned to "Fullscreen"
[OK].....[Cancel]
If I click [OK], the button "f" will be assigned for "Faster" and the "Fullscreen" will have "Unset" value.
I think it nice.
Thanks
