0.60: Request: Large images, "Zoom100%" always go to XY=0
quapurna
Post by quapurna »
XnViewMP 0.60
Windows7 32
Xubuntu1304
Halo.
If I open a long image using "Fit image to window, large only" , then I zoom it to "100%" ; XnViewMP always zoom to the centre of the image.
Can we have an option so that (for the above scenario), XnViewMP will focus on the XY=0 ?
In this case, the option "Setting > View > tab: View" > "Reset XY (not fit)" does not work.
Thank you.
quapurna
Re: 0.60: Large images, "Zoom100%" always go to XY=0
Post by quapurna »
Perhaps when I use XnViewMP, the better term for me is for "reading" images rather than for seeing/looking/watching them.
I use it for reading many screen shots of various sites and most of them consist of text.
That is why, after having an overview of a single image (Fit image to window) and I want to start reading (Zoom:100%), I want to see the XY=0 position.
This request is for both View mode and Browse mode's Preview pane.
NB: An add-on of Firefox "Screengrab fix version" is great for screen shooting the whole html page; not only the part appears on screen.
Thanks.
m.Th.
Re: 0.60: Request: Large images, "Zoom100%" always go to XY=
Post by m.Th. »
Fair enough for me. Use XnView as reader and not as viewer.
m. Th.
