With older versions of XnView it was possible to select multiple files and open all together with an external editor with the context menu. In version 1.80.1 now the entries of the external programs in the context menu are greyed out if more than 1 file is selected. Is this intentionally done now this way?
Greetings
Hannes
Open multiple files with "Open with"
Re: Open multiple files with "Open with"
Ok, i'll change itHannes wrote:With older versions of XnView it was possible to select multiple files and open all together with an external editor with the context menu. In version 1.80.1 now the entries of the external programs in the context menu are greyed out if more than 1 file is selected. Is this intentionally done now this way?
