Why is "-high_res" needed for RAW?
jimoe
Post by jimoe »
Nikon d700
nconvert 6.17
When converting Nikon's NEF (raw) format to TIFF or JPEG, the "-high_res" option is required to get the full image size of 4284x2844. The default is 1/2 of those dimensions.
Why is that option required?
Why would NConvert choose the half size by default?
DOS386
Re: Why is "-high_res" needed for RAW?
Post by DOS386 »
jimoe wrote:Why would NConvert choose the half size by default?
Funny ... I also had noticed this BUG :-(
Currently a bit odd usage. Default should be full resolution and the option should be "-half_res" to force XnView to use the half resolution of Raw files and thus be more speedy.
DOS386
"-half_res"
Post by DOS386 »
Should be fixed now since NC 6.50 / XN 2.10 :
http://newsgroup.xnview.com/viewtopic.p ... 85#p115480
(not yet tested)
          -half_res             : Load half resolution (Camera RAW)
"-high_res" is gone :-)
