Conversion from RAW to TIFF, PNG, or JPEG is darker
jimoe
Post by jimoe »
nikon d700
nconvert 6.17
Using the command line
nconvert  -high_res -raw_autobalance -raw_camerabalance -raw_autobright -out jpeg -o ../%.jpg *.nef
produces output that is noticeably darker than the original NEF image. Looking at the histograms confirms this since the overall curves are the same, only compressed toward the dark side.
Other than the "-raw_" options, is there an automated way to get the correct brightness?
oops66
Re: Conversion from RAW to TIFF, PNG, or JPEG is darker
Post by oops66 »
... You can try with an icc profile, for you ... NikonD700.icc ...
http://ufraw.sourceforge.net/Colors.html
jimoe
Post by jimoe »
I tried using "-icc_in" with the d700 profile available from the site you referenced. All it seemed to do was excessively increase the color saturation without any brightness benefit.
The "-icc" option made no difference.
oops66
Post by oops66 »
...No luck ... but you can try some others icc ;-)
