The Properties gets trapped still in use for a previous picture in view mode upon opening a new picture from Windows Explorer.
1.) In XnViewMP, open a image's from "recent files" to view it in view mode
2.) Open the image's "Properties" by using the command (I click "Properties" from toolbar)
3.) Now go to Windows Explorer and double-click to open an associated JPG to open in view mode
4.) Notice that at "Properties" dialog is still in use from previous opened picture
0.60 win-x86: Properties dialog of previous image file
budz45
Re: 0.60 win-x86: Properties dialog of previous image file
I can't reproduce, same thing if you drag&drop a file?
budz45
I don't use drag & drop.xnview wrote:I can't reproduce, same thing if you drag&drop a file?
Ok I will make a video and send you since you already have my ini to reproduce with.
budz45
Ok, to reproduce you have to keep the Properties dialog opened with the current picture while double-clicking on an image in Win Explorer to open in XnViewMP
Not really a bug, the property dialog is for other tab, you need to close it and reopen it
