0.60: Batch Convert (Crop then Convert) Works Properly
quapurna
Post by quapurna »
Halo, XnView Developer.
XnViewMP 0.60
Windows7 32
THANK YOU. IT WORKS. :) :) :)
I have 76 jpg images with the same dimension 1366 x 768 pixels. They are the print screens of an online journal.
I set the crop: 10 pixels from the left, 20 pixels from the top, cropped area: 500 x 700 pixels.
I set the feature to then convert those images to png.
It worked smoothly.
I can not imagine if I had to do it one by one.
So, THANK YOU SO MUCH.
Re: 0.60: Batch Convert (Crop then Convert) Works Properly
Thanks to you!
