Slideshow hangs
neoncortex2
Slideshow hangs
Post by neoncortex2 »
if i use "show all files (recursive)" than open an image in fullscreen and than click the slideshow play button the slideshow starts. But at some time is simply stops. I have the option "Loop on the file list" enabled.
Sometimes the pictures are shown only once sometimes the list is repeated a few times but eventually the slideshow stops. Sometimes it continues after manually changing to the next picture.
Cheers
Re: Slideshow hangs
Do you have only image files?
