just looking into setting up a digital asset management system for a large collection of scanned stills. have used xnview and nconvert for simpler things like batch conversions and such. i love the cross-platform nature of xnview in its various flavors and am curious as to how usable it might be as a tool for managing this archive. several questions:
can i use mp to apply metedata in batches?
can i search an archive by metedata?
can i create collections?
thanks. i guess that's a start.
BabaG
asset management?
m.Th.
Re: asset management?
...hehehe....BabaG wrote:just looking into setting up a digital asset management system for a large collection of scanned stills. have used xnview and nconvert for simpler things like batch conversions and such. i love the cross-platform nature of xnview in its various flavors and am curious as to how usable it might be as a tool for managing this archive. several questions:
BabaG
(*) "we" as in 'Photo/Imaging Market' not "we" as in "You and me".
...but let's answer to your questions: (btw, sorry to say - it is metAdata not metEdata... sorry once again
If you mean ratings/stars, colors and keywords/categories, yes.can i use mp to apply metedata in batches?
You can do it by using mouse and/or shortcuts - also you have a compare window in which you can do your rating and/or coloring.
(Feel free to post here feedback, improvements & RFCs). IMHO, Compare Window is good now, but can be much better.
If you mean IPTC for the formats which supports this (ie. JPG, TIFF), yes.
If you mean to add/edit photo comments, yes.
If you mean on-disk search on a gazillion of EXIF/IPTC tags, then yes. On-disk search is well designed, and relatively fast but, of course, slow compared with an in-DB search which will be near-to-realtime.can i search an archive by metedata?
The in-DB search is cooking here: http://newsgroup.xnview.com/viewtopic.php?f=60&t=28345
Feel free to go there and give feedback! We need your input.
If you mean filtering by keywords / ratings (stars) / colors - yes, it supports.
Did I forget something?...
In 0.60, just one: The tagged files.can i create collections?
...but one of the important database redesigns was support for Albums/Collections in 0.56->0.60 release. Now the DB backend is ready (I hope) and in the next release (I hope
See the corresponding discussion here: http://newsgroup.xnview.com/viewtopic.php?f=60&t=28322
Don't hesitate to give any feedback you think that it will help us improve the things.
In your opinion, which are the most important things for a DAM which we should implement in the next (sub)release and how do you see them implemented?
m. Th.
BabaG
hmm. just installed the dmg and it crashes when i try to open after the install.
this is on a:
mac pro 1,1
osx 10.6.8 32bit
does 0.60 require something newer?
<edit>
just noticed that the download seems to be 64 bit only. will this change or am i stuck? i have four macs here, all 32 bit and mp doesn't run on any.
</edit>
here'sthe full crash report:
BabaG
this is on a:
mac pro 1,1
osx 10.6.8 32bit
<edit>
</edit>
Process: XnViewMP [231]
Path: /Applications/XnViewMP.app/Contents/MacOS/XnViewMP
Identifier: com.xnview.XnView
Version: 0.60 (0.60)
Code Type: X86-64 (Native)
Parent Process: launchd [110]
Date/Time: 2013-07-16 14:08:38.890 -0700
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 157686 sec
Crashes Since Last Report: 2
Per-App Crashes Since Last Report: 2
Anonymous UUID: 40A8B32F-9E7D-40E5-8C77-DB32D3B21F9D
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Symbol not found: _kCFWebServicesProviderDefaultDisplayNameKey
Referenced from: /Applications/XnViewMP.app/Contents/MacOS/../Frameworks/QtWebKit.framework/Versions/4/QtWebKit
Expected in: /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Binary Images:
0x100000000 - 0x1008f3fff +com.xnview.XnView 0.60 (0.60) <B9FB435C-8925-3A70-9816-551C19447438> /Applications/XnViewMP.app/Contents/MacOS/XnViewMP
0x100c7c000 - 0x102059fe7 +QtWebKit 4.9.3 (compatibility 4.9.0) <60B1050C-5EFD-356F-8335-A4C6425C7B53> /Applications/XnViewMP.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit
0x1023f5000 - 0x102438fe7 +phonon 4.4.0 (compatibility 4.4.0) <4C271806-FF81-302B-BD4F-4E13017B4E54> /Applications/XnViewMP.app/Contents/Frameworks/phonon.framework/Versions/4/phonon
0x10244d000 - 0x102de3fff +QtGui 4.8.4 (compatibility 4.8.0) <E04F767C-9302-3411-8D1E-C630B54D19CB> /Applications/XnViewMP.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
0x102f42000 - 0x1031e9fff +QtCore 4.8.4 (compatibility 4.8.0) <53D39FCD-EC4E-3542-88C8-FC064F259391> /Applications/XnViewMP.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
0x103236000 - 0x103282fff +QtSvg 4.8.4 (compatibility 4.8.0) <1B035EE4-BAAB-3596-8DC7-3F6E410E917B> /Applications/XnViewMP.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg
0x103292000 - 0x1032d5fff +QtXml 4.8.4 (compatibility 4.8.0) <2F0517E1-E2BC-3B54-84F1-93F4DA890B18> /Applications/XnViewMP.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
0x1032e2000 - 0x103416fe7 +QtNetwork 4.8.4 (compatibility 4.8.0) <2952DBBE-9B2C-32EB-8CDF-E4D8667887C6> /Applications/XnViewMP.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
0x7fff80003000 - 0x7fff80004fff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff8000e000 - 0x7fff8002ffe7 libPng.dylib ??? (???) <D8EC7740-EE32-865A-2F75-C9EDE2135510> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8022f000 - 0x7fff80270fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff80271000 - 0x7fff8027cff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff80298000 - 0x7fff80521ff7 com.apple.security 6.1.2 (55002) <772E1B13-8271-02F8-B1FE-023592A7AED7> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff80e30000 - 0x7fff80e9afe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff80e9b000 - 0x7fff80e9bff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff80f65000 - 0x7fff80f74fef com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff80f75000 - 0x7fff810b3fff com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8113e000 - 0x7fff8119efe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8119f000 - 0x7fff811a1fff libRadiance.dylib ??? (???) <BF694EE5-6FDA-553A-CC89-F7135618E9C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff811a2000 - 0x7fff811dcfff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <4F2A4397-89BD-DEAC-4971-EE838FFA0964> /usr/lib/libcups.2.dylib
0x7fff811e9000 - 0x7fff811e9ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff81248000 - 0x7fff8125ffff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff81260000 - 0x7fff81315fe7 com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff81316000 - 0x7fff8131cff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff81597000 - 0x7fff81597ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff815cd000 - 0x7fff81686fff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff81687000 - 0x7fff81689fff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8173a000 - 0x7fff81862ff7 com.apple.MediaToolbox 0.484.60 (484.60) <F921A5E6-E260-03B4-1458-E5814FA1924D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff81871000 - 0x7fff81871ff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff81872000 - 0x7fff81897ff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff81898000 - 0x7fff818b8fff com.apple.DirectoryService.Framework 3.6 (621.15) <9AD2A133-4275-5666-CE69-98FDF9A38B7A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff818b9000 - 0x7fff81bedfef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff81bee000 - 0x7fff81befff7 com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff81bf0000 - 0x7fff81d25fff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff81d26000 - 0x7fff81d27ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff81d28000 - 0x7fff81d28ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff81d31000 - 0x7fff8253bfe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8254a000 - 0x7fff82563fff com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff82564000 - 0x7fff82a6aff7 com.apple.VideoToolbox 0.484.60 (484.60) <F55EF548-56E4-A6DF-F3C9-6BA4CFF5D629> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff82a6b000 - 0x7fff82e08fe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff82e63000 - 0x7fff82eabff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff82eac000 - 0x7fff82eacff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff82efd000 - 0x7fff82f7cfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff83001000 - 0x7fff83057fe7 libTIFF.dylib ??? (???) <2DBEC120-DAA7-3789-36A2-A205BCDF2D72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff832d4000 - 0x7fff832d7fff com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff83300000 - 0x7fff8330eff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff8343f000 - 0x7fff83442ff7 libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff83443000 - 0x7fff83520fff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff8362d000 - 0x7fff8363ffe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff83640000 - 0x7fff83655ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff83771000 - 0x7fff8382efff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff83944000 - 0x7fff839d0fef SecurityFoundation ??? (???) <3F1F2727-C508-3630-E2C1-38361841FCE4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff839d1000 - 0x7fff83a81fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff83a9b000 - 0x7fff83bbafe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff83bbb000 - 0x7fff83bbeff7 com.apple.securityhi 4.0 (36638) <AEF55AF1-54D3-DB8D-27A7-E16192E0045A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff83bbf000 - 0x7fff83bbfff7 com.apple.Carbon 150 (152) <23704665-E9F4-6B43-1115-2E69F161FC45> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff83bc0000 - 0x7fff83e42fff com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff83e53000 - 0x7fff83e69fe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff83e6a000 - 0x7fff83f4ffef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff83f50000 - 0x7fff83fa3ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff83fa4000 - 0x7fff83fe5fef com.apple.CoreMedia 0.484.60 (484.60) <6B73A514-C4D5-8DC7-982C-4E4F0231ED77> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff83fe6000 - 0x7fff8400dff7 libJPEG.dylib ??? (???) <08758593-6436-B29E-1DA8-F15597835EC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8400e000 - 0x7fff8409efff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff84555000 - 0x7fff84590fff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff84591000 - 0x7fff845d6fff com.apple.CoreMediaIOServices 140.0 (1496) <D93293EB-0B84-E97D-E78C-9FE8D48AF58E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x7fff846ef000 - 0x7fff84717fff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff847a8000 - 0x7fff847bcff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff847bd000 - 0x7fff847fefff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff8486e000 - 0x7fff84875fff com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff84876000 - 0x7fff8487cff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff84a20000 - 0x7fff84a41fff libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
0x7fff84a6c000 - 0x7fff84ab5fef libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff84ab6000 - 0x7fff84b34ff7 com.apple.CoreText 151.13 (???) <5C6214AD-D683-80A8-86EB-328C99B75322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff84c3a000 - 0x7fff84c3ffff libGIF.dylib ??? (???) <3BAD0DE8-8151-68B0-2244-A4541C738972> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff84ed1000 - 0x7fff84ee2ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
0x7fff84ee3000 - 0x7fff84efeff7 com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff84f49000 - 0x7fff84fe9fff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff84fea000 - 0x7fff85161fe7 com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff861cd000 - 0x7fff864cbfff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff864cc000 - 0x7fff8668dfef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff866d8000 - 0x7fff8678eff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff86791000 - 0x7fff867b4fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff867da000 - 0x7fff8684bff7 com.apple.AppleVAFramework 4.10.27 (4.10.27) <6CDBA3F5-6C7C-A069-4716-2B6C3AD5001F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff868a6000 - 0x7fff868d1ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib
0x7fff86b5b000 - 0x7fff86baaff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <0731C40D-71EF-B417-C83B-54C3527A36EA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff87027000 - 0x7fff87036fff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff87037000 - 0x7fff8714dff7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib
0x7fff872af000 - 0x7fff873c9fff libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff873ca000 - 0x7fff8744fff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8749b000 - 0x7fff87535fff com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff875b3000 - 0x7fff875c7fff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff87943000 - 0x7fff87b02fff com.apple.ImageIO.framework 3.0.6 (3.0.6) <92882FD3-CB3F-D0BE-DDDA-43B4BEE10F58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff87b03000 - 0x7fff87b58ff7 com.apple.framework.familycontrols 2.0.2 (2020) <8807EB96-D12D-8601-2E74-25784A0DE4FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff87b59000 - 0x7fff87c1afef com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff87c1b000 - 0x7fff87ceffe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff87d0c000 - 0x7fff87d58fff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff87d7c000 - 0x7fff87dc3ff7 com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff881cc000 - 0x7fff888c8ff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff888df000 - 0x7fff888e4fff libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff88958000 - 0x7fff8895cff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff8895d000 - 0x7fff88973fef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff88974000 - 0x7fff889a5fff libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff889a6000 - 0x7fff889abff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8921f000 - 0x7fff893ddfff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <97A75BFB-0DB6-6F44-36B0-97B7F7208ABB> /usr/lib/libicucore.A.dylib
0x7fff8946e000 - 0x7fff89e68ff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff89fa5000 - 0x7fff8a3e8fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff8a3f5000 - 0x7fff8a565fff com.apple.QTKit 7.7 (1793) <6C8A8451-1FE5-79F5-3D6D-8FA846866609> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8a632000 - 0x7fff8a6affef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff8a6b0000 - 0x7fff8a6faff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff8a701000 - 0x7fff8a7c3fe7 libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8a7d2000 - 0x7fff8a7d8ff7 IOSurface ??? (???) <8E302BB2-0704-C6AB-BD2F-C2A6C6A2E2C3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
Model: MacPro1,1, BootROM MP11.005D.B00, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 8 GB, SMC 1.7f10
Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
Memory Module: global_name
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
Network Service: Ethernet 2, Ethernet, en1
PCI Card: ATY,RadeonX1900, sppci_displaycontroller, Slot-1
Serial ATA Device: Maxtor 7Y250M0, 233.76 GB
Serial ATA Device: ST3250820AS P, 232.89 GB
Serial ATA Device: WDC WD20EARX-00PASB0, 1.82 TB
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8206, 0x5d200000 / 3
USB Device: USB OPTICAL MOUSE, 0x15d9, 0x0a4d, 0x5d100000 / 2
USB Device: USB Keyboard, 0x04d9 (Holtek Semiconductor, Inc.), 0x1503, 0x3d100000 / 2
FireWire Device: built-in_hub, Up to 800 Mb/sec
m.Th.
At
http://www.xnview.com/en/xnviewmp/
says 32 & 64 bit. Try once again, be more attentive at unpacking etc. ...but perhaps Pierre forgot to put the 32bit build in the package or so. It happens. He monitors these forums and usually he answers and fix quickly such problems. Unfortunately it seems than he's now in holidays for one-two weeks. Try to contact him directly through email sending him the link to this thread.
BabaG wrote:hmm. just installed the dmg and it crashes when i try to open after the install.
this is on a:
mac pro 1,1
osx 10.6.8 32bit
<edit>
</edit>
here'sthe full crash report:BabaGCode: Select all
Process: XnViewMP [231] Path: /Applications/XnViewMP.app/Contents/MacOS/XnViewMP Identifier: com.xnview.XnView Version: 0.60 (0.60) Code Type: X86-64 (Native) Parent Process: launchd [110] Date/Time: 2013-07-16 14:08:38.890 -0700 OS Version: Mac OS X 10.6.8 (10K549) Report Version: 6 Interval Since Last Report: 157686 sec Crashes Since Last Report: 2 Per-App Crashes Since Last Report: 2 Anonymous UUID: 40A8B32F-9E7D-40E5-8C77-DB32D3B21F9D Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0 Dyld Error Message: Symbol not found: _kCFWebServicesProviderDefaultDisplayNameKey Referenced from: /Applications/XnViewMP.app/Contents/MacOS/../Frameworks/QtWebKit.framework/Versions/4/QtWebKit Expected in: /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation Binary Images: 0x100000000 - 0x1008f3fff +com.xnview.XnView 0.60 (0.60) <B9FB435C-8925-3A70-9816-551C19447438> /Applications/XnViewMP.app/Contents/MacOS/XnViewMP 0x100c7c000 - 0x102059fe7 +QtWebKit 4.9.3 (compatibility 4.9.0) <60B1050C-5EFD-356F-8335-A4C6425C7B53> /Applications/XnViewMP.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit 0x1023f5000 - 0x102438fe7 +phonon 4.4.0 (compatibility 4.4.0) <4C271806-FF81-302B-BD4F-4E13017B4E54> /Applications/XnViewMP.app/Contents/Frameworks/phonon.framework/Versions/4/phonon 0x10244d000 - 0x102de3fff +QtGui 4.8.4 (compatibility 4.8.0) <E04F767C-9302-3411-8D1E-C630B54D19CB> /Applications/XnViewMP.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui 0x102f42000 - 0x1031e9fff +QtCore 4.8.4 (compatibility 4.8.0) <53D39FCD-EC4E-3542-88C8-FC064F259391> /Applications/XnViewMP.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore 0x103236000 - 0x103282fff +QtSvg 4.8.4 (compatibility 4.8.0) <1B035EE4-BAAB-3596-8DC7-3F6E410E917B> /Applications/XnViewMP.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg 0x103292000 - 0x1032d5fff +QtXml 4.8.4 (compatibility 4.8.0) <2F0517E1-E2BC-3B54-84F1-93F4DA890B18> /Applications/XnViewMP.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml 0x1032e2000 - 0x103416fe7 +QtNetwork 4.8.4 (compatibility 4.8.0) <2952DBBE-9B2C-32EB-8CDF-E4D8667887C6> /Applications/XnViewMP.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork 0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld 0x7fff80003000 - 0x7fff80004fff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib 0x7fff8000e000 - 0x7fff8002ffe7 libPng.dylib ??? (???) <D8EC7740-EE32-865A-2F75-C9EDE2135510> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff8022f000 - 0x7fff80270fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff80271000 - 0x7fff8027cff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff80298000 - 0x7fff80521ff7 com.apple.security 6.1.2 (55002) <772E1B13-8271-02F8-B1FE-023592A7AED7> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff80e30000 - 0x7fff80e9afe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff80e9b000 - 0x7fff80e9bff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff80f65000 - 0x7fff80f74fef com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff80f75000 - 0x7fff810b3fff com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff8113e000 - 0x7fff8119efe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff8119f000 - 0x7fff811a1fff libRadiance.dylib ??? (???) <BF694EE5-6FDA-553A-CC89-F7135618E9C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff811a2000 - 0x7fff811dcfff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <4F2A4397-89BD-DEAC-4971-EE838FFA0964> /usr/lib/libcups.2.dylib 0x7fff811e9000 - 0x7fff811e9ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff81248000 - 0x7fff8125ffff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fff81260000 - 0x7fff81315fe7 com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff81316000 - 0x7fff8131cff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore 0x7fff81597000 - 0x7fff81597ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff815cd000 - 0x7fff81686fff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib 0x7fff81687000 - 0x7fff81689fff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff8173a000 - 0x7fff81862ff7 com.apple.MediaToolbox 0.484.60 (484.60) <F921A5E6-E260-03B4-1458-E5814FA1924D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x7fff81871000 - 0x7fff81871ff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff81872000 - 0x7fff81897ff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff81898000 - 0x7fff818b8fff com.apple.DirectoryService.Framework 3.6 (621.15) <9AD2A133-4275-5666-CE69-98FDF9A38B7A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService 0x7fff818b9000 - 0x7fff81bedfef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff81bee000 - 0x7fff81befff7 com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fff81bf0000 - 0x7fff81d25fff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff81d26000 - 0x7fff81d27ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff81d28000 - 0x7fff81d28ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff81d31000 - 0x7fff8253bfe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff8254a000 - 0x7fff82563fff com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff82564000 - 0x7fff82a6aff7 com.apple.VideoToolbox 0.484.60 (484.60) <F55EF548-56E4-A6DF-F3C9-6BA4CFF5D629> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x7fff82a6b000 - 0x7fff82e08fe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff82e63000 - 0x7fff82eabff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff82eac000 - 0x7fff82eacff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff82efd000 - 0x7fff82f7cfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff83001000 - 0x7fff83057fe7 libTIFF.dylib ??? (???) <2DBEC120-DAA7-3789-36A2-A205BCDF2D72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff832d4000 - 0x7fff832d7fff com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fff83300000 - 0x7fff8330eff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib 0x7fff8343f000 - 0x7fff83442ff7 libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff83443000 - 0x7fff83520fff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8362d000 - 0x7fff8363ffe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib 0x7fff83640000 - 0x7fff83655ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff83771000 - 0x7fff8382efff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff83944000 - 0x7fff839d0fef SecurityFoundation ??? (???) <3F1F2727-C508-3630-E2C1-38361841FCE4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff839d1000 - 0x7fff83a81fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff83a9b000 - 0x7fff83bbafe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib 0x7fff83bbb000 - 0x7fff83bbeff7 com.apple.securityhi 4.0 (36638) <AEF55AF1-54D3-DB8D-27A7-E16192E0045A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fff83bbf000 - 0x7fff83bbfff7 com.apple.Carbon 150 (152) <23704665-E9F4-6B43-1115-2E69F161FC45> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff83bc0000 - 0x7fff83e42fff com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff83e53000 - 0x7fff83e69fe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff83e6a000 - 0x7fff83f4ffef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff83f50000 - 0x7fff83fa3ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff83fa4000 - 0x7fff83fe5fef com.apple.CoreMedia 0.484.60 (484.60) <6B73A514-C4D5-8DC7-982C-4E4F0231ED77> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia 0x7fff83fe6000 - 0x7fff8400dff7 libJPEG.dylib ??? (???) <08758593-6436-B29E-1DA8-F15597835EC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff8400e000 - 0x7fff8409efff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff84555000 - 0x7fff84590fff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff84591000 - 0x7fff845d6fff com.apple.CoreMediaIOServices 140.0 (1496) <D93293EB-0B84-E97D-E78C-9FE8D48AF58E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices 0x7fff846ef000 - 0x7fff84717fff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff847a8000 - 0x7fff847bcff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff847bd000 - 0x7fff847fefff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff8486e000 - 0x7fff84875fff com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff84876000 - 0x7fff8487cff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff84a20000 - 0x7fff84a41fff libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib 0x7fff84a6c000 - 0x7fff84ab5fef libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff84ab6000 - 0x7fff84b34ff7 com.apple.CoreText 151.13 (???) <5C6214AD-D683-80A8-86EB-328C99B75322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff84c3a000 - 0x7fff84c3ffff libGIF.dylib ??? (???) <3BAD0DE8-8151-68B0-2244-A4541C738972> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff84ed1000 - 0x7fff84ee2ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib 0x7fff84ee3000 - 0x7fff84efeff7 com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff84f49000 - 0x7fff84fe9fff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff84fea000 - 0x7fff85161fe7 com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff861cd000 - 0x7fff864cbfff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff864cc000 - 0x7fff8668dfef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib 0x7fff866d8000 - 0x7fff8678eff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib 0x7fff86791000 - 0x7fff867b4fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff867da000 - 0x7fff8684bff7 com.apple.AppleVAFramework 4.10.27 (4.10.27) <6CDBA3F5-6C7C-A069-4716-2B6C3AD5001F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x7fff868a6000 - 0x7fff868d1ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib 0x7fff86b5b000 - 0x7fff86baaff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <0731C40D-71EF-B417-C83B-54C3527A36EA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer 0x7fff87027000 - 0x7fff87036fff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff87037000 - 0x7fff8714dff7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib 0x7fff872af000 - 0x7fff873c9fff libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x7fff873ca000 - 0x7fff8744fff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff8749b000 - 0x7fff87535fff com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff875b3000 - 0x7fff875c7fff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff87943000 - 0x7fff87b02fff com.apple.ImageIO.framework 3.0.6 (3.0.6) <92882FD3-CB3F-D0BE-DDDA-43B4BEE10F58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff87b03000 - 0x7fff87b58ff7 com.apple.framework.familycontrols 2.0.2 (2020) <8807EB96-D12D-8601-2E74-25784A0DE4FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls 0x7fff87b59000 - 0x7fff87c1afef com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff87c1b000 - 0x7fff87ceffe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff87d0c000 - 0x7fff87d58fff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib 0x7fff87d7c000 - 0x7fff87dc3ff7 com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff881cc000 - 0x7fff888c8ff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff888df000 - 0x7fff888e4fff libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff88958000 - 0x7fff8895cff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib 0x7fff8895d000 - 0x7fff88973fef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib 0x7fff88974000 - 0x7fff889a5fff libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff889a6000 - 0x7fff889abff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fff8921f000 - 0x7fff893ddfff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <97A75BFB-0DB6-6F44-36B0-97B7F7208ABB> /usr/lib/libicucore.A.dylib 0x7fff8946e000 - 0x7fff89e68ff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff89fa5000 - 0x7fff8a3e8fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff8a3f5000 - 0x7fff8a565fff com.apple.QTKit 7.7 (1793) <6C8A8451-1FE5-79F5-3D6D-8FA846866609> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit 0x7fff8a632000 - 0x7fff8a6affef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib 0x7fff8a6b0000 - 0x7fff8a6faff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff8a701000 - 0x7fff8a7c3fe7 libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff8a7d2000 - 0x7fff8a7d8ff7 IOSurface ??? (???) <8E302BB2-0704-C6AB-BD2F-C2A6C6A2E2C3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib Model: MacPro1,1, BootROM MP11.005D.B00, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 8 GB, SMC 1.7f10 Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB Memory Module: global_name Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports Network Service: Ethernet 1, Ethernet, en0 Network Service: Ethernet 2, Ethernet, en1 PCI Card: ATY,RadeonX1900, sppci_displaycontroller, Slot-1 Serial ATA Device: Maxtor 7Y250M0, 233.76 GB Serial ATA Device: ST3250820AS P, 232.89 GB Serial ATA Device: WDC WD20EARX-00PASB0, 1.82 TB Serial ATA Device: WDC WD20EARX-00PASB0, 1.82 TB Parallel ATA Device: OPTIARC DVD RW AD-7170A USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8206, 0x5d200000 / 3 USB Device: USB OPTICAL MOUSE, 0x15d9, 0x0a4d, 0x5d100000 / 2 USB Device: USB Keyboard, 0x04d9 (Holtek Semiconductor, Inc.), 0x1503, 0x3d100000 / 2 FireWire Device: built-in_hub, Up to 800 Mb/sec
m. Th.
BabaG
thanks, m.Th.
i actually did try more than once with different downloads: once from the main mp site download link and another time from the link at the top of this forum, though, they may link to the same file. the link on this forum i noticed says only 64 bit. the link on the website says both. windows notes distinct 32 and 64 bit downloads. the mac download is a single one.
on the mac there's not much to the unpacking. if its tar or tgz it just extracts to a single app icon, nothing else. the dmg (disk image) download does pretty much the same. on the mac that's a mountable image that opens with a window and, again, a single app icon with a graphic option to drag the app to the user's applications folder. no indication whether the app is 32 or 64 bit.
i'm wondering if there's something funny going on like you have to hold the 'option' key (alt on pc) while opening the file to get it to open as 32 bit. would be odd but, barring a mistaken omission of the 32 bit version it's all i could think of.
think i'll spare pierre the pestering while he's on vacation. would like to know if it's an oversight, though.
thanks again,
BabaG
thanks again,
BabaG
m.Th.
Yes, most probably it is an oversight. AFAIK he triggers manually the builds. He develops with the Win 32bit build and when this is close to release then builds and packages for other platforms. For example, I know that Win 64bit counts as a separate platform. OTOH, it could depend on what OS do you have. For ex. CMake has different package for different (older eg. Tiger) Mac OSX variants:BabaG wrote:thanks, m.Th.
thanks again,
BabaG
http://www.cmake.org/cmake/resources/software.html
Could you try to download it (it is a small program), install and see what's working for you?
m. Th.
Known issue, will be fixed in next releaseBabaG wrote:hmm. just installed the dmg and it crashes when i try to open after the install.
BabaG
seems like a big one when an entire platform is excluded! hope the fix is soon.
anxious to try it all. seems like this is a very significant release.
thankyou, pierre,
BabaG
thankyou, pierre,
BabaG
BabaG
and just for my own planning purposes, is this expected to be a long or short release cycle?
should i be checking the forum daily or monthly?
thanks,
BabaG
thanks,
BabaG
The 0.61 will be available todayBabaG wrote:and just for my own planning purposes, is this expected to be a long or short release cycle?
